View Full Version : Competitive Driving Mode Inoperable
JAH
05-07-06, 12:52 PM
I just noticed that attempting to put my 05 V into "Competitive Driving Mode" is not working. When I push the traction control button twice within 5 seconds it simply cycles the traction control on and off - but no message on the display (as before) that I am now in the comp driving mode. Same result when I push the button in the dash. I recently installed new wheels and tires with tire pressure sensors. My TPS is "reading" the stack of tires in my garage, but not all of them. Sometimes two wheels, sometimes three. Could it be that the system unable to monitor the tire pressure sensors is preventing it from going into comp driving mode? I am curious if anyone else has experienced this or has a simple work-around. Thanks!
mike041357
05-07-06, 01:18 PM
Re-program the TPS for the ones on the car. The FAQ knows all.....
http://www.cadillacfaq.com/faq/answers/tprepro.html
Chef
05-07-06, 01:23 PM
I just noticed that attempting to put my 05 V into "Competitive Driving (http://www.cadillacforums.com/forums/#) Mode" is not working. When I push the traction control button twice within 5 seconds it simply cycles the traction control on and off - but no message on the display (as before) that I am now in the comp driving mode. Same result when I push the button in the dash. I recently installed new wheels and tires (http://www.cadillacforums.com/forums/#) with tire pressure (http://www.cadillacforums.com/forums/#) sensors. My TPS is "reading" the stack of tires (http://www.cadillacforums.com/forums/#) in my garage, but not all of them. Sometimes two wheels (http://www.cadillacforums.com/forums/#), sometimes three. Could it be that the system unable to monitor the tire (http://www.cadillacforums.com/forums/#) pressure sensors is preventing it from going into comp driving mode? I am curious if anyone else has experienced this or has a simple work-around. Thanks!
I have had that happen as well. Sometimes it simply goes off after working on the car but always seems to just go back on by itself. So far it's all good.
Good Luck --
Chef
wildwhl
05-07-06, 01:33 PM
Correct - if the system finds an error in any of the TPS readings (missing, too high psi, too low psi, etc) then Comp mode will not be allowed.
WW
JAH
05-08-06, 06:29 AM
Thanks. I found the answer in the FAQs after I posted the question. I moved the wheels with the sensors to the back of my basement. Hopefully that is far enough!
Flyboy
05-08-06, 07:04 AM
Should be....I had to move my sensors to a shed in my back yard AND wrap them in tin foil.......sensitive little guys!!!!
50 4Ever
05-08-06, 12:21 PM
Worried about Aliens???:worship:
Robby2006
05-08-06, 05:53 PM
I thought that you wear the tin foil on your head to protect from Aliens....:stirpot: :bighead:
Forget saving the tires......:alchi:
