View Full Version : 3/8"-ish metal line off of throttle body runs where... ..?
CBARTMAN
05-06-06, 12:59 PM
Hey I did some work on my ht4100 (head gasket) and all I have left to do is hook up a few lines. I cant figure out where one metal line that runs off the throttle body goes. Its a prebent, steel or aluminum line and it has a threaded fitting on one end that attaches to the rear throttle body. The other end of this line has about a 4" piece of rubber hose clamped onto it, like it would attach to another steel line of sorts or some other sort of fitting.
Does anyone know where this line runs? I posted a similar post about a year ago and never really got around to working on the car, but now i have time... and still have the same problem... Please help! :)
HUF
05-06-06, 01:27 PM
To brake booster or PCV?
The Ape Man
05-07-06, 08:56 AM
Brake booster.
noahsdad
05-07-06, 09:02 AM
If by "back of the throttle body" you mean the firewall side, there are two lines there. One goes to the MAP sensor, the other to the brake booster.
Tailfin
05-07-06, 09:05 AM
I'm agreeing brake booster here... MAP sensor would not be 3/8"-ish.
