ctappraiser
05-02-06, 12:04 PM
I just bought a 69 DeVille with a 472. My problem is rough idle. The engine already has new wires, electronic ignition, new plugs and pcv. I have replaced the carb, put new vacuum line for the brake booster, and adjusted the timing. The dwell is 34 degrees, timing 5 degrees, idle speed 550 rpm. The exhaust sounds good with no miss firing "puffs". Fuel mix adjustment seems to have no effect. My plan is compression check next. I have looked at all of the vacuum lines at the carb and no leaks there. Off idle, it runs great. The former owner put a flowmaster clone muffler which was way to loud. I added a resonator which helped make it a little quieter. Any suggestions?
Love this car. Also have a 74 Eldroado. Drives very smooth but I like the DeVilles performance.
