View Full Version : ISC Motor question
getbig
05-02-06, 11:53 AM
Hello all… I was just wondering if this sounds right with you guys, when I override the ISC motor (ps03 – warmer button) to extend its arm, it takes about 5 sec to extend it all the way out and with click click click noise. But If I command it to retract it’s self, from the extend point, it will take about 2 min to retract it’s self all the way down. Also when it does there is a steady click, click, click noise.
I'm thinking of replacing it but I want to get the members' blessing first.
So there is 2 concerns; :confused:
1- the time difference from extending the plunger and retracting the plunger
2- the click click click noise. Again only happens when it retracts.
THANKS!!!!!:thumbsup:
chevelle
05-02-06, 01:25 PM
It certainly sounds like the ISC motor is failing. It shouldn't click like that when retracting and it should retract fairly quickly not take 2 minutes.
When you install the new one retract it fully and make sure that there is about a .030 gap between the ISC plunger and the throttle lever with the throttle completely closed. Turn the plunger to adjust the gap.
getbig
05-02-06, 02:14 PM
That is what I thought, thanks for the reply, I'm going to search around for a new one. Funny thing is, the car drives fine and it idle fine too. But the clicking noise, is bugging me. thanks for the help..... again.
HUF
05-02-06, 03:14 PM
Here is the tool I made to adjust ISC motor's plunger easily.
caddydaddy
05-02-06, 03:53 PM
How much did that cost you? LOL! :)
HUF
05-02-06, 04:24 PM
I know only the exact cost of parts! lol
getbig
05-02-06, 04:59 PM
Hey HUF and CaddyDaddy,
So do you guys think I should change the motor???
HUF
05-02-06, 05:38 PM
Yes, it is bad. It should move much faster in both directions, and should not make clicking noises at all. Besides, I believe it makes pretty loud ratcheting noises when you shut the engine down.
Always follow Chevelle's advice. I cannot recall any case he would be wrong.
caddydaddy
05-02-06, 08:47 PM
Yeah, it sounds like it's taking way to long to retract. Mine doesn't take 2 minutes!
