Hot4.1
05-01-06, 09:47 PM
Takes 30 seconds or more to start. Starts immediately when I pour gas down the throat. Restarts immediately - no problem. Runs smooth. Check Engine light intermittent.
Could it be an electrical problem? What do these codes mean?
The codes are:
E20 - Open Fuel (http://www.cadillacforums.com/forums/#) Pump Circut Feedback Signal
E22 - Open TPS Signal
E25 - EST Circut Problem in Bypass Mode
E30 - ISC RPM Out Of Range
E52 - PCM Memory Reset (See Note)
Someone had taped over the Check Engine light. I didn't notice it until last night.
I bought a new fuel pump, but this beast has a sway bar? directly under the rear axle and I can't find a place to put my jack stands.
Someone said replacing the fuel pump is a pain. What kind of pain?
:confused:
The codes are:
:confused:
