CaddylacBrougham
01-22-04, 04:00 PM
Ok well the other problem with the car is that my left rear power windows is not working. I have asked people and they say check the motor but is that my first step and if so how complicated is it? :confused:
| View Full Version : ummm window please go down CaddylacBrougham 01-22-04, 04:00 PM Ok well the other problem with the car is that my left rear power windows is not working. I have asked people and they say check the motor but is that my first step and if so how complicated is it? :confused: ssstealth 01-22-04, 07:40 PM This will sound stupid... but try it, sometimes it works. The biggest problem with the rear windows is that they don't get used enough and the motors bind up. Sit in the back seat and hold the switch down while slamming the door shut. Make sure that the lockout switch up front is not engaged first. You can also trys pounding on the inside door panel while holding the switch down. A good practice is to run ALL of the windows up and down at least once a week to keep everything "loosened up". Good Luck!!! CaddylacBrougham 01-23-04, 12:10 AM Hey thank you very much i will try it tommorow if I can find my car in the snow | |
