View Full Version : Vats
Andrew
01-21-04, 09:33 PM
The VATS on my 1991 eldorado is acting up. Can anyone tell me which wire is supposed to have the live feed, as currently I have no live feed to the ignition barrel.
I know you can override this by inserting a resistor of the same value as the one in the key. Does anyone know if the VATS bypass kits for a remote stater would have the same effect.
01STS
01-21-04, 10:44 PM
Painless wiring makes a kit to delete VATS for TPI cars. It was new last year and I think you should be able to use it on your Caddy. It isn't a chip but a small box with wires you tie into the existing system on your car. I don't know all there is about it but check out their website for more info.
