cadi2000
04-23-06, 09:24 PM
I just purchased a 2000 Deville DTS w/103000 miles. The car drives nice and seems to have good acceleration and braking. However, there are some problems with with the car.
Here are the problems that exist:
#1 Traction Control light stays on for extended periods, but sometimes stays off
#2 The (driver side) rear window does not go down (a click is hear when button is pressed)
#3 Rear vents blow hot air when A/C is on. Possible that a previous post touches on the fix: http://www.cadillacforums.com/forums/cadillac-deville-1985-2005-including-1985/36634-rear-c-blows-hot-2000-deville.html
I have read the codes and being new to this car, I dont know where to start. If someone could help place the codes to the problem and help diagnose the root cause of it, I would be most appreciative. Thanks in advance.
VTD B1009 EEPROM Checksum Error
VTD B2734 Coded Key Controller Memory Failure
ABS C1295 Brake Lamp Switch Circuit Open
IPM B0429 Temp Control #3 Rear Circuit Range / Performance
IPM B1004 Keep Alive Memory (KAP)
IRC U1016 Loss of Class 2 Communications with KCM
IRC U1016 Loss of Communications with PCM
PCM P1599 Engine Stall or Near Stall
PCM 1617 Engine Oil Level Switch Circuit
PCM 1624 Customer Snapshot Requested Data Available
