1969cadillaceldorado
04-22-06, 12:30 AM
ok its been 3 days it runs like shit after i put the seafoam shit down the carb yes i might of put a little to much down the carb was trying to kill it but now it wont idle cant really rev it so what should i do?
The Ape Man
04-22-06, 10:02 AM
pull out the spark plugs and look. They might be loaded up with schtuff.
90Brougham350
05-13-06, 10:31 PM
Can't really use too much Seafoam, I usually use the whole bottle. I bet Apeman nailed it; your plugs got fouled when you poured it in, probably those years and years of carbon build-up just breaking loose.
05-13-06, 10:33 PM
ok its wont idle but it revs ok i cleaned all the plugs but idk i guess ill change them
Junkman
05-13-06, 11:55 PM
The best plugs to use in my opinion are Nippendenso, NGK, or Bosch. I have had nothing but trouble from Champions. AC are not much better. Change the plugs and I bet that the problem will go away. Usually does.... Junk...
Tailfin
05-16-06, 11:51 AM
Unless it's different for the older engines, I'd stay away from Bosch. Those stupid Platinum +2/+4 shroud the spark.
BluEyes
05-16-06, 07:39 PM
Bosch also makes normal sparkplugs - anything other than a single ground strap is a gimmick and a waste of money. The spark can only jump to one.
If you want better plugs, get platinums and don't worry for the next 100,000 miles.
