: Rwd N*
94CaddyConcours
04-21-06, 09:51 PM
I remember somone had a RWD N* with a Vette trans. Not sure if it is a 4.0 or 4.6 which doesnt really make a different since both stock use a 4t80e
Zorb750
04-21-06, 10:30 PM
700R4 / 4L60 / 4L60E will bolt.
94CaddyConcours
04-22-06, 02:34 PM
Thanks
What I was looking for.
danbuc
04-22-06, 02:36 PM
Oe of the bellhousing bolt holes isn't lined up though. You may end up having to cut it of, and re weld it back on in the right place. I believe this is what CHR-Fab does with the 700R4 tranny's they build.
eldorado1
04-22-06, 10:12 PM
V6 bellhousing *only*.
parts68
04-22-06, 10:50 PM
that would be 60 deg v-6
Zorb750
04-23-06, 09:19 AM
The 700R4 from a 4.3 will fit as I recall. They may have had to put an adapter of some sort, but I believe it more or less lined up. Usably at least.
eldorado1
04-23-06, 09:31 AM
It will not, the 4.3 uses the chevy 350 bolt pattern
cart69
04-24-06, 01:13 PM
yep gotta be a 2.8 chevy bellhousing and the tp must be cut and rewelded to clear the starter. i have seen t-5 manual haousings used as well with the mods check chrfab.com the have pics and an explanation as well as prices for them doing it
parts68
04-24-06, 09:28 PM
2.8,3.1,3.4 are all 60 degree
