View Full Version : fusebox messed up
grkmofo@aol.com
04-20-06, 07:46 PM
my 97 eldorado would lose power... so i went in the hood and started moving wires to get it ro run which works but it would be dead a few mins later so i fliped open the fusebox cover and pressed on it and that would turn the car back on but when i would wiggle the fuse box it would turn off untill i press on it so i removed the cover to exposed all the fuseboxes and found that the box with the big fuses seems to be messed up, just by touching it it would make the car lose power i would have to force the fusebox to the left and keep it there to have power so i stuck a chunk of wood between the big fuses and the block fuses and it seems like its working now... has anyone else experienced this b4?
Krashed989
04-20-06, 09:04 PM
Can you list what those fuses are for?
What I would do first is I would detach the fuse block from the car (wires still attached) and then spray where the wires enter the fuse block with some of this stuff:
http://i29.photobucket.com/albums/c296/Krashed989/100_0343.jpg
I got that spray from a store called GasPro.
Ranger
04-20-06, 09:56 PM
You need to pull the battery power and then pull hte fuse box. You'll probably find a loose wire on the back side.
