View Full Version : Replacement Plugs
Chef
04-19-06, 03:58 PM
Looks like cylinder 7 & 8 plugs were shot ---had the stock ACDelco ---
What's the best plugs that you're using that are cooler:rant2:
specs please as I'm here at the shop:worship:
1MEANV
04-19-06, 04:27 PM
msd only
1MEANV
04-19-06, 04:27 PM
they have a set custom made for lsx engines
VELOSE
04-19-06, 04:34 PM
My car is running weird too lately. When I start it up, it seems to spark but, it cranks over very slowly. The other day when I had to leave the hospital in a hurry, the car was cold. I drove out of there slowly because I knew the car was cold but, it seemed like it was misfiring. Could it be the plugs too?
Chef
04-19-06, 06:07 PM
Velose,
It might be. My car was popping and backfiring and felt lean. Sort of bogged in each gear (1st & 2nd) then the air caught up to 3rd but still was not healthy. Basically it was running on 7 cylinders. Check out my Running rich thread -- put new plugs in and voila -- for now:alchi:
Hope this helps....
Chef
VELOSE
04-19-06, 06:35 PM
I need to take it in to the dealer anyway for a new rear sail panel. I'll have them run a check on the codes. If I need new spark plugs, I'll get some MSD or something.
Thanks Chef....;)
chiro444
04-19-06, 10:28 PM
All the nitrous guys run NGK TR6's because they are supposed to be the best when it comes to a cool plug.
stkshkr
04-19-06, 11:29 PM
NGK tr6 iridiums love superchargers, Get some magnacore wires while you're at it
CADI-V
04-20-06, 10:30 PM
Hello
CADI-V
04-20-06, 10:31 PM
:crybaby: Hello
CADI-V
04-20-06, 10:32 PM
:thehand: Cadi V
CADI-V
04-20-06, 10:32 PM
:stirpot: Cadi-v
CADI-V
04-20-06, 10:33 PM
:thumbsup: Cadi-v
StealthV
04-20-06, 11:08 PM
50. :cheers:
Working on 3000; thus this worthless post. :coffee:
Maggie owners - factory original plugs = bad. Change them this weekend if you are still running them. The platinum tips on the factory plugs retain more heat than a traditional plug and this increases the risk of detonation. To prevent that, one needs a cooler running spark plug such as the popular NGK TR6. If one is running a 2.6" pulley, the next step cooler TR7 may be in order.
Chef
04-20-06, 11:57 PM
:thumbsup: Thanks ---
VELOSE
04-21-06, 01:05 AM
Sounds good, I'll get new plugs and wires this weekend. Thanks Rick.:thumbsup:
stkshkr
04-21-06, 10:39 AM
FWIW when I removed my factory plugs they were AC Delco 41-985 Iridiums
kcinside
04-21-06, 12:55 PM
What gap to use on the plugs?
VELOSE
04-21-06, 03:01 PM
I have a set of Denso Iridium Power IK20 plugs. I'm on the Denso website and see that these will go on a CTS 3.2L. They don't have the V on the list. Do you guys think they'll work on the V? I paid $12 for each one at the time. Also, what is the worst that can happen if they aren't meant for the V?
EDIT: I just did a search for a 2004 CTS-V. I need IT60 Denso Plugs. They don't have 2005 CTS-V on their list.
Screw it, I'm going to Napa autoparts for some NGK-TR6 plugs right now. Thanks again Rick.
stkshkr
04-21-06, 09:15 PM
The AC Delco's come pre-gapped at .40, My NGK TR6's are at .35
VELOSE
04-21-06, 09:56 PM
I'm getting some mixed info. Can someone confirm the part no. for these TR6 plugs? Some TR6 plugs are $3 ea and others are $11 ea. It also doesn't help when Autozone, Napa, and Kragens autoparts can't find a match. I know they won't because the recommended plug for a stock V is the TR55.
Also, are these TR6 plugs "resister" type plugs? If they are, aren't they a downgrade over "iridium" stock ones?
stkshkr
04-21-06, 11:16 PM
You probably want NGK 50 TR6 IX, these are the iridium's. The NGK 50 TR6 is a "regular" type plug. The TR6's (recommended for SC and N2O) are one range colder than the TR55 or TR55 IX.
http://www.thunderracing.com/catalog/?action=categories&pcid=102 $6.99
VELOSE
04-22-06, 09:46 PM
I went onto south valley florida's site. They are a sponsoring vendor. They had the exact plugs I need for my maggied V. Paid $27.95 shipped. Not a bad deal.
Thanks for your help guys.
