View Full Version : after a&b solenoid
musgttang
04-16-06, 12:21 PM
i replaced a & b solenoid and only worked for one time.the same code comes back on and overdrive not working and im pretty shure i put evrything the same way i took it off.:confused:
acklac7
04-17-06, 12:14 AM
Your not the first one with these symptoms...Did you install the "L" bracket that came with the update kit? (it bolts into the valve body and keeps the filter in place)...Forgetting to install the "L" bracket is the NO.1 problem associated with the solenoid repair...If you did install the L bracket I would bet the valve body is clogged and trans. fluid cannot get to the solenoids.
