gixxer_751
04-14-06, 10:35 AM
i finally got my wing but need the paint code for the cranberry 1997 catera... i'd appreciate any help.
| View Full Version : Paint Code: cranberry catera? gixxer_751 04-14-06, 10:35 AM i finally got my wing but need the paint code for the cranberry 1997 catera... i'd appreciate any help. guardian 04-14-06, 12:00 PM Take a look here http://www.paintscratch.com/ Fill in your information under "how to order" and press "go". But beware the warning posted about potential code confusion. Good luck!:) AllenPacla 04-14-06, 09:41 PM Or you can go to expresspaint.com and they have instructions on how to look for the correct paint code of your car. Normally, the information can be found in the trunk, in that small compartment in the passenger side of the trunk. The information you have to look for is printed on the cover of that small compartment. If your car has the OEM paint, then the information should tally. Check and compare it with what you can find at the site i have above. gixxer_751 04-15-06, 04:25 PM cool.. thanks for the help, the first linked hooked up a pretty user friendly layout, here's the info just in case someone else needs all paint codes for a '97 cadillac catera Ivory 11U/WA164D Ocean Pearl Clearcoat 14U/WA170D Aubergine Metallic Clearcoat 18/WA325D Forest Pearl Clearcoat 46U/WA166D Sand Pearl Clearcoat 68U/WA165D Cranberry Pearl Clearcoat 75U/WA169D Ebony 80U/WA168D Slate Pearl Clearcoat 86U/WA171D Sage Metallic Clearcoat 97U/WA167D | |
