View Full Version : throttle angle
DeVillish
03-21-03, 10:03 AM
I just found out about all the OBD stuff you can do and looked at my throttle angle. At WOT its at 75.9 deg. Would making it open closer to 90 degs help make more power? and if so, how can i do it? Oh, its a 90 4.5.
Katshot
03-21-03, 02:03 PM
Once the idle spec is set, there's not much you can do about the WOT spec, it's basically self-setting. I would make sure you aren't getting any kind of obstruction either in the TB, or at the gas pedal (like a floor mat limiting pedal travel etc.).
Also, are you working the throttle from the pedal or manually at the TB?
DeVillish
03-21-03, 02:29 PM
the pedal. that kinds sucks, i was hopping that would be a way to get more power out of it, its not that easy to find stuff for 4.5s. I'll check if there is anything blocking the pedal or TB.
jadcock
03-21-03, 04:03 PM
What your throttle position sensor (TPS) reports and what your actual throttle angle is may not necessarily be the same. Verify with an assistant that your throttle blades are exactly 90* at WOT -- they probably only open about 80* -- even if you operate it at the throttle body. It's probably physically limited to somewhere less than 90*.
The important setting is the TPS voltage. I think it's supposed to be about 5 volts at WOT. Verify this with your service manual, if you have one. If it's close to that value at WOT, and close to the idle value (.45 volts maybe...not sure), it's adjusted properly.
Katshot
03-21-03, 04:36 PM
As I recall, it should be about .6 at idle and about 5 at WOT.
Verify WOT by throttle lever contacting throttle stop.
jadcock
03-21-03, 04:55 PM
Yes, Kevin said in many fewer words what I was trying to say about the throttle being physically limited to less than 90 degrees probably. If it contacts the WOT stop, you're at WOT.
DeVillish
03-21-03, 11:25 PM
ok, thanks, i'll check out the volts tomarrow
DeVillish
03-22-03, 01:30 PM
i looked a little closer and its not the pedal or cable, theres a stopper on the outside of the TB that stops the little lever that is conected to the cable. If you look at my crapy dawing you can see what i mean. I was thinking if i shave off that little bump on the stopper it should open closer to 90*. Any thoughts?
jadcock
03-22-03, 03:02 PM
Naw, I wouldn't shave anything there (don't take that the wrong way). They designed the stopper there for the throttle lever at an exact height for a reason. What's already there, you should leave IMHO.
Katshot
03-22-03, 05:22 PM
That's the throttle-stop screw. If you are hitting it, you're getting full throttle.
