View Full Version : Faulty CAGS?
Mat347
04-12-06, 01:01 PM
I recently installed the CAGS I purchased used, now my CE light is on!?. I thought that was the entire purpose of using the eliminators, so it wouldn't come on. Is there simply a resistor that I can check? Anyone know what the resistance should be?
Thanks for any info!
StealthV
04-12-06, 02:31 PM
The resistance should be in the 2 to 3 k ohm range depending on who made it.
First thing that pops into my head is the connector fully seated?
Is it installed in the correct harness?
Is it a Stealth !CAGS?
Mat347
04-12-06, 04:01 PM
The CAGS I have uses the OEM connectors with silicon/shrinkwrap to close the open ends....is this a StealthCAGS?? I'm quite sure I got them in there all the way, but I'll double check.
Is there another harness that uses the same plug which goes to the end of the tranny??? I saw about 3 others but they had different connectors.
StealthV
04-12-06, 05:30 PM
It's not a Stealth version. Want me to send you one that works? :)
kanned
04-12-06, 06:53 PM
Like my pappy used to say.. No one ever got fired for buying a StealthV CAGS! eliminator.
Or was that IBM? :)
Mat347
04-12-06, 08:28 PM
Let me check mine out first..:thumbsup:
