: Racing days are over.....for awhile
stkshkr
04-11-06, 08:30 PM
During my weekly inspection I found the front seal on the rear diff leaking. I knew it was just a matter of time.
The KARS bolts for the pinion support were also extremely loose.
I wanted to get the V into the 11's and was very close (2 100ths of a sec away). I pass the torch to someone else. I will resume when the diffs in development become available. I will miss the trips down the 1/4 mile. :(
WW
Now you know how it's holding up
Vendetta-V-
04-11-06, 08:40 PM
The glass half-full side of your story is at least you caught the problem before it festered too much. Do you have an 06 rear or modded 05?
stkshkr
04-11-06, 08:45 PM
06 diff.
Vendetta-V-
04-11-06, 08:54 PM
06 diff.
***gulps in fear***
wildwhl
04-11-06, 09:31 PM
My front seal is leaking too...but your dealer WILL replace it. I have a diff on the shelf that is usable - but not perfect (had some gear chatter when removed, was disassembled by a vendor for inspection and ideas to improve and reassembled).
Go for the 11's. A USABLE back up diff is here, and a UPS or FedEx tag away.
WW
CVP33
04-11-06, 09:36 PM
I, uh, I wa, oh nevermind.
CTSV05
04-12-06, 12:06 AM
Just resnug the nuts, and it will be good
Mine have loosened up once or twice depending on My driving habits. You can always double nut them too.
A leaking seal won't cause trouble, unless you run it dry
stkshkr
04-12-06, 07:15 AM
OK. Line Lock goes in today, if the weather holds.... an 11 this weekend.
I must be nuts:bonkers: :cookoo:
Flyboy
04-12-06, 07:49 AM
You Can Do It!!!
riverrat
04-12-06, 01:08 PM
Edgewater or TriState? I'd like to see you get that 11:worship:
VELOSE
04-12-06, 01:17 PM
Anyone have hot cheeleaders to post up? Maybe that will cheer up Stkshkr. :D
Edit: Here's a Raiderette.
http://www.cheerleader.com/raiderettes/06/Raiders06Cal5.jpg
Luna.
04-12-06, 02:23 PM
Very impressive...
Staxxin
04-12-06, 02:48 PM
Very impressive...
I agree with that!!! :thumbsup:
Chef
04-12-06, 03:22 PM
:highfive: Good Luck!!!!!:worship:
Chef
stkshkr
04-12-06, 05:42 PM
RiverRat
Probably Tristate on Sat, if the weather holds up, looks like rain on Fri.
CVP33
04-12-06, 06:37 PM
You're nucking futs! No guts no glory though.
riverrat
04-12-06, 09:33 PM
I'll have to find TriState on a map - it's been about 30 years since I've been there:eek:
