View Full Version : HID KIT Install
Blacklac02
04-10-06, 08:10 PM
Does anyone have instructions or a guide to help me install an 6000k HID kit in my Escalade? I received a kit with no instructions wtf? Everyone says its easy, but I have no clue as to what wire does what.
Any help would be appreciated.
Thanks.
TheCaddyKidd
04-10-06, 11:11 PM
its pretty simple.. not sure on the kit you have.. do you have just the plug and play or did it come with a wire harness that has relays and fuses? if its jsut plug and play then just take the red or white wire and plug it into the socket that has the positive connection.. normally negative is always black so whatever colored wire is there is usually the positive one.. then connect the black into the hole that is negative and wrap electrical tape and ur good to go.. i wish i knw what you have in front of you so i could give better directions..
Blacklac02
04-11-06, 01:40 AM
Thanks caddy kid. I think I have the plug and play kit. The kit is from jdm. http://www.japanjdm.com/hid.htm . I think I may have figured it out. I put some pics up. Where does the brown connector in pic 2 plug into?
TheCaddyKidd
04-11-06, 03:17 AM
from the looks of it that brown connector should connect diractly to the stock wire harness where you would plug your stock bulb into.. there should only be one way of clipping it on..
