View Full Version : AC Problem...is there a fuse or relay for the AC?
babenson
04-09-06, 08:20 PM
My AC just stopped working a few weeks ago, it was working fine, then NOTHING..... When I listen for the pump to turn on when I start the ac, I dont hear anything, and I used to. I checked the main fuse panel, but it does not appear that there is a fuse for the ac. Any help would be great, location of the fuse, relay or any other trouble shooting methods.
Thanks, I am in Dallas, so unless I get some help soon, I am going to melt.:bouncy:
tlarwa
04-11-06, 02:46 PM
A/C relay is #5 and can be found by the battery under the hood. The A/C relay fuse is in the fuse block under the steering wheel, and is #33 (far left on the top row. It's a 30A fuse).
Boris
04-13-06, 10:10 PM
and if all the fuses look good than check your refrigerant pressure.
Might be low and the low pressure switch is keeping it off.
