Ext05
04-09-06, 05:00 PM
I am trying to find some lights to make my fog lights look the same as my HID's..... They are the factory headlights if anyone can re direct me to where I can get these bulbs it would be much appreciated! :confused:
| View Full Version : Fog Lights Ext05 04-09-06, 05:00 PM I am trying to find some lights to make my fog lights look the same as my HID's..... They are the factory headlights if anyone can re direct me to where I can get these bulbs it would be much appreciated! :confused: JCM1 04-09-06, 05:08 PM http://www.eautoworks.com/html/light_bulbs.cfm Ext05 04-09-06, 05:39 PM THat link sent me to the place to buy lights but which ones would you recomend (brand) that would look the same color as my HID's? JCM1 04-09-06, 07:45 PM The Escalade specifies using 880's however, you can also use 890, 892, 893, 884, 885, 899. The difference is the angle of the base and the wattage however, the base socket and wiring socket are the same. An 880 is only 27 watts and if you're going to use a bulb that looks like HID you should get a brighter wattage due to the bulb having a blue tint on it. http://www.eautoworks.com/html/ORD-1-1-1-6753.cfm Those are 37.5 watts and offer a blue tint light. I have used a pair of 9006's like these. They look very close to HID however, they're not as bright as HID. I don't know if it is possible to convert 880's to an HID kit. Ext05 04-14-06, 04:07 PM Thanks..... I ordered them so hopefully they look right....... hcvone 04-14-06, 04:38 PM The Escalade specifies using 880's however, you can also use 890, 892, 893, 884, 885, 899. The difference is the angle of the base and the wattage however, the base socket and wiring socket are the same. An 880 is only 27 watts and if you're going to use a bulb that looks like HID you should get a brighter wattage due to the bulb having a blue tint on it. http://www.eautoworks.com/html/ORD-1-1-1-6753.cfm Those are 37.5 watts and offer a blue tint light. I have used a pair of 9006's like these. They look very close to HID however, they're not as bright as HID. I don't know if it is possible to convert 880's to an HID kit. They have 880 HID kits now. :) 03EscaladeOn26s 04-14-06, 04:51 PM A buddy of mine got a whole hid system bulbs and all in tact out of a smashed 2006 dts and gave them to me and he wired them into my fog light wires now i have real hid in the headlights and fogs lookd pretty nice till something happened to the driver side one and it doesnt work anymore so i have no fogs untill i get time to bring it to him to check JCM1 04-15-06, 12:39 PM They have 880 HID kits now. :) That's good to know. I always find the 9006, 9004, and 9007's but never anything for fog lights. Do you know where you can find them? JCM1 04-15-06, 12:48 PM Thanks..... I ordered them so hopefully they look right....... Like I said, the only concern I would have is the brightness issue due to the blue tint but, due to the fact you are increasing the wattage from stock it should make up for the differnece. I was accually suprised to learn that the Escalade used only 880's as fog lights. That definatly leaves room for upgrading. As I said, I have used the 9006's of the same bulb and I liked them. A lot depends also on lense design but, the Escalade has a good lense design with nice, clean reflectors. After you install them post again and let me know. | |
