babenson
04-09-06, 10:47 AM
I just changes out the EBTCH in my 98 catera. This seemed to fix the ABS lights and the TC lights as well as the speedo, but now the AC doesn't work and the brakes are out. I depress the brake pedel all the way to the floor and nothing happens. I refilled the brake fluid to see if it was just out and still nothing!
Anyone have any clue as to what happened?
ANy help appreciated.
guardian
04-10-06, 10:10 PM
. . . but now the AC doesn't work and the brakes are out. I depress the brake pedal all the way to the floor and nothing happens. I refilled the brake fluid to see if it was just out and still nothing!
OK I have no clue on the AC. No clue.
On the brakes, reading between the lines it appears the fluid was low at one point to where it was necessary for you to add fluid. I suspect the fluid became so low that air entered your brake lines.
So JMHO:
Bleed the brakes.
babenson
04-11-06, 01:48 PM
do you know where the fuse or relay switch is at for the AC?
