View Full Version : 94 cadillac concours
boxer615
04-08-06, 11:10 PM
I GET THE FOLLOWING CODES FOR THE SERVICE RIDE CONTROL MESSAGE:
S021 .......................... Left Rear Damper Solenoid Valve Short to Ground/Open
S026 ......................... Right Rear Damper Solenoid Valve Short to Ground/Open
S038 ................... Electronic Level Control Exhaust Valve Short to Ground/Open
S044 .................................................. ... Lift or Dive Signal Fault
S055 .......................................... Resistor Module Short to Ground/Open
S073 ................................................ Right Rear Accelerometer Fault
WHAT DO I NEED TO CHANGE OR IS IT A WIRING PROBLEM?:bonkers:
caddydaddy
04-09-06, 10:41 PM
I'd check the wiring, or you have some bad shocks, ELC motor and an accelerometer! That's a lot of bad parts, if it's not an electrical short somewhere.
