urbanski
04-03-06, 06:18 PM
Well, by now we all know how to remove our door panels and deaden our doors. I'll add to that with another 60sqft of RAAMmat, but the twist is the Ensolite i used this time
http://www.raamaudio.com/
Following the very simple procedure of: rip out the damn plastic crap.
http://img110.imageshack.us/img110/189/doorbefore25zw.th.jpg (http://img110.imageshack.us/my.php?image=doorbefore25zw.jpg)
Deaden fully (man i did a crappy job before)
http://img155.imageshack.us/img155/7176/doorbefore7lx.th.jpg (http://img155.imageshack.us/my.php?image=doorbefore7lx.jpg)
After about 15ft
http://img110.imageshack.us/img110/9109/doormatted9fj.th.jpg (http://img110.imageshack.us/my.php?image=doormatted9fj.jpg)
Apply Ensolite using very sticky spray adhesive.
http://img110.imageshack.us/img110/2200/doordone1am.th.jpg (http://img110.imageshack.us/my.php?image=doordone1am.jpg)
Reapply door bits and pieces :)
I did not take pics, but I concentrated some time around the side view mirrors. There's actually a large gap between mirror bottom and door, which leads to 2 large holes inside the door that rain/wind/crap can get in. Don’t believe me? Remove your door panel, there were 2 leaves, dirt, rain spots, and dust inside. Removing the mirrors I covered the holes and gap from the outside and inside with several layers of mat, then of course Ensolite’d the interior (behind the “triangle”).
Cost: $150
Weight: 20lbs
Time: 10 hours
Wounds: several
Beers: 3
Difficulty: 3
PITA Factor: 4
Do it again? Hell yeah. Every time you deaden, you get more results. That damn wind HOWL from my “front” (which I suspected was from around the mirror) is way down. WAY. I deadened my A-pillar so much the trim panel barely fits. This was my LAST ditch effort to knock down wind noise. Can’t deaden the windows.
I suspect I will cut down on rain intrusion. Of course never cover your door drain holes. Do use Ensolite to replace the crappy plastic. It knocks down road noise well, too.
After about 15ft
Cost: $150
Weight: 20lbs
Time: 10 hours
Wounds: several
Beers: 3
Difficulty: 3
PITA Factor: 4
