jadcock
03-20-03, 08:31 AM
I received an interesting email the other day from a gentleman who, after installing an open K&N filter on his Eldorado, got the same results as I did (little increased power, worse mileage). I found it interesting and wanted to share. Note: both my car and his car (to the best of my knowledge) have no other modifications. It is certainly advisable to make other mods to the vehicle to be able to achieve a performance increase with a K&N filter. The stock intake system is fully capable of supplying enough air to a stock engine. See my writeup on my homepage...this gentleman's email is below:
> > > Last night, while playing computer, I found your web site. I was
just
> > > two weeks too late. I have two 1993 Eldorado Cadillacs and have been
> > > working on the idea to do just what you did using the cone type K&N
> > > filter. I used an RF1015 which is slightly larger than what you used.
> > > This one had an inside flange diameter of four inches and a three inch
> > > ABS forty five degree sewer elbow fits like a glove into the K&N
filter.
> > > The other end fit into the stock tube to the throttle body. I also
> > > fashioned a box out of sheet metal and painted it with low gloss black
> > > engine paint to put around the filter. We took a quick trip up to
> > > Wheatland Wyoming from our home here in Lakewood Colorado to test the
> > > installation. I too found the mileage to be a bit less than before.
The
> > > engine did not seem to have any more performance but did it sound
great.
> > > If I had found your web site sooner it would have saved me about 70
> > > dollars. After I read your report I went to the garage and put the
stock
> > > air box back in.
> > > Do you think the K&N filter that replaces the AC 1096C stock filter
> > > would have some benefit even though you say it does not filter as well
> > > as the stock application. I have a friend in Virginia that has also
> > > wanted to modify his Eldorado as well. We will both be watching your
web
> > > site for more good information. I will try to send a picture of my
> > > attempt at what you did.
just
filter.
The
great.
stock
> > > air box back in.
web
