View Full Version : Door panel Removal
jreXt
04-01-06, 08:36 AM
i Just got a 2003 Ext the front speakers seem to go on and off when i go over a bump im thinking the speaker wire is loose is the driver side door panel something can do my self or is it something i should go to the dealer to get done
T-Dizzy
04-01-06, 09:44 AM
Two screws hold on the door panel. One under the armrest, and the other one is hidden behind the manual door lock switch. Pop it off with a flathead (careful not to cut the leather) and you'll see the screw. Once both screws are out, just slide the door panel upwards. It is 'hooked' in place by 3 or 4 plastic hangers.
- Tony
drdiesel
04-01-06, 03:04 PM
You'll also need to remove the triangle plastic cover that is right above the door panel. It just pulls stright out, with a little force. Then the door panel will lift straight up and out. You'll notice four or five mounting tabs at the bottom of the panel, just set thoes back into the door and let the panel sit there. The speaker clips into the door. Just unclip the speaker and fix your problem.
urbanski
04-01-06, 03:10 PM
get some Dynamat in there while you have that panel off :)
its totally easy, way easier panel to remove than my Vs
jreXt
04-01-06, 04:38 PM
Thanks for the help fellas got it done found out these are not bose speakers their cheap 20.00 sound logics gonna replace them with jl audio xr650 and the back xr525 anyone have these speakers :thumbsup:
05 Cadillac Escalade
04-01-06, 04:44 PM
I don't suggest JL Audio. I suggest Treo. A company that is far superior to JL Audio in my opinon. It will cost you a little bit more, but I think it is worth it. Good luck and let us know what you do. Post some pictures of your EXT when you get a chance. Oh yeah, welcome to the forum.
Thanks.
jreXt
04-09-06, 07:27 PM
ok another problem i noticed with these cheap speakers i have to move the wires around for the speaker to work and when i drove and went over a bump speaker would go out so i thought it was a loose wire i bought jl zrs 6.5s and cut wire re did everything and jls dont work at all could it be bad speaker wire any one know :confused:
Blacklac02
04-10-06, 08:16 AM
Sounds like the problem to me, but I'm no expert. I would have assumed the same thing.
jreXt
04-10-06, 10:58 AM
yea i know it doesnt make sense i guess i try one more time if not ill take it to an audio shop :confused:
