Hello, do they still make the Lockpick for our cars? I can't seem to find a place to purchase one. Thanks!
The one with the toggle switch would allow you to toggle it 'ON' and leave it like that ... however while you have a lockpick activated your Navigation unit will be useless until you deactivate it again as it blocks GPS, and VSS information from getting to the radio.All I want to do is to be able to use my , or watch a DVD, automatically whenever I'm driving, without turning anything on or off. Is it possible to do that, or will it always have to be turned on manually when starting the car?
I have my 06 lockpick but have an 08 v now. Did you just plug it in? Do I have to cut the push button toggle switch?06 uses a on/off button that I mounted under the dash. The 08+ uses the mute button on the wheel.
I have the 06 model installed on my 08 because I carried it over from my last STS. You can use it on the newer models but you can NOT use the new models on the 06. Not sue of the part #
I have never had any issues with mine s!ince I purchased it back in 2011... Now finding one today is the real challenge.
Because the 05-06 STS used 3 checks to determine motion while the 07+ only used 2...Rboughne1 said:So Nav-TV got back to me that their lockpick model, the GMVIMSTS07, will not work on my 2006 STS V, as it fits only 2007 -2011 STS. How could it work on an 07 V, and NOT the 06 V, when the 06 and the 07 are identical? I understand that the 08-09 are different form an 06, but the 07? I call bullsh!t...I just got a lazy ass customer service rep who doesn't know the difference between the V and the regular STS. Does anybody know the correct actual Part# THEY utilized in their build? King of Lacs?!?! Anyone?!?! I'm also trying to work the problem at both ends, and get an answer for what I would need from Coastal "E" Tech Lockpicks to see what the correct model # would have been for the 06 V. ---------- Nope. Nothing for 06
