View Full Version : Cranking but not starting.. fuel pump relay? 99esteees 03-29-06, 07:18 PM I've got the dreaded "it cranks but wont start" problem. It always eventually starts, and it doesn't matter whether the car is cold or hot. The engine doesn't miss out, nor does it ever stall. I checked the FPR and it checked out good, but I went ahead and replaced it. I'm doubting it's the fuel pump, and I am starting to wonder if it could be a bad fuel pump relay. Is this a possibility? Can anyone help me locate this sucker so I can get it replaced? Thanks :worship: weister42 03-29-06, 07:58 PM The relay is in the relay box in the engine compartment.
Does it start easier when you press on the gas pedal? If so then you probably have the same exact problem as me - seeping fuel injectors. I start having the crank but not start thing and I don't have a faulty FPR but I replaced it anyway just like you:highfive: . Problem didn't go away and I replaced the fuel pump relay like you did:highfive: . Problem didn't go away and I had a mechanic cleaned my fuel injectors. Problem didn't go away and replaced a leaking fuel pressure release button. Problem got a little better but it's still there. Took it to another mechanic and he told me all 8 of my injectors are seeping gas, so if I let it warm up then park for more than 30 minutes she starts in a rich fuel condition. Depress the gas pedal(opening the throttle body) would help clearing out excess fuel. If I park for 4 hours or so she'll start fine.
My mechanic told me he has never seen such a thing, but he told me all 8 injectors are bad. 99esteees 03-29-06, 08:49 PM The relay is in the relay box in the engine compartment.
Wow, thats a big mess right there. The likely hood of all 8 injectors being bad sounds absurd, but who knows. My problem is not helped my pressing on the gas pedal. It does it whether the car has sat 5 minutes from a 3 hour trip, or 8 hours in the freezing cold. I've yet to change the fuel pump relay actually. I was looking at the relays, and I seen a STRT1 and and STRT2, but nothing about Fuel Pump under the hood.
My fuel pressure tested fine. I'm going to test it while cranking tomorrow. I'm hoping the fuel pump relay might just be the problem. eldorado1 03-29-06, 08:54 PM My mechanic told me he has never seen such a thing, but he told me all 8 injectors are bad.
I've had several injectors leak on me, causing a backfire on startup. I think the northstar injectors are just prone to leaks. Mine didn't even have 70k on them. I believe and someone correct me if I'm wrong, but if you have a faulty oil pressue sending unit, it could cause you the same problems. 99esteees 03-31-06, 02:10 PM I believe and someone correct me if I'm wrong, but if you have a faulty oil pressue sending unit, it could cause you the same problems.
That would be nice to know. I have replaced the fuel pump relay, and FPR with no luck. I am getting no fuel pressure with the key in the ON position, but I get 40psi with the car running, once it finally starts. This is VERY aggravating. No fuel pressure with key on means that the pump is not being energized during the crank cycle (key on), so you have to build oil pressure to activate the pump. Look at the relay again. Is it the right one? Are the contacts lean? Check the circuit. I think you have the gremlin cornered. A FSM will be invaluable at this point. 99esteees 03-31-06, 02:49 PM No fuel pressure with key on means that the pump is not being energized during the crank cycle (key on), so you have to build oil pressure to activate the pump. Look at the relay again. Is it the right one? Are the contacts lean? Check the circuit. I think you have the gremlin cornered. A FSM will be invaluable at this point.
Got the relay from the dealer, and it had no effect. I tried changing it with other relays, which are all the same part number. Contacts are clean. I'm narrowing it down to either a bad fuel pump, or bad connection somewhere between the fuse box and the fuel pump. It's definitely a gremlin somewhere. eldorado1 03-31-06, 03:22 PM Didn't you say it eventually ran when cranked enough? That has to be the relay circuit. When oil pressure builds, it clicks the oil pressure switch on, which bypasses everything and turns the fuel pump on. If it runs, the fuel pump is fine, and the wiring to the fuel pump is fine. It's the circuit that controls the relay that's giving you problems... 99esteees 03-31-06, 04:00 PM Yes it always eventually fires over. The relay must be fine. How can I further diagnose the circuit myself? Is it possible? Sounds like the check valve in the fuel sender isn't doing it's job. It's there to keep fuel from pooring back into the tank after shut off, and maintain residual pressure in the lines until the engine is started again. If this checkball is bad, it will effectively drain the fuel lines dry, and you'll have to wait for fuel to be pumped back up though the lines all the way up to the injectors. Just a thought. I' haven't seen that too much on these cars, but it is possible. eldorado1 03-31-06, 05:01 PM Yes it always eventually fires over. The relay must be fine. How can I further diagnose the circuit myself? Is it possible?
When you first get in your car to start it.... and you turn the key to run (NOT start), do you hear the fuel pump turn on for a couple seconds? Listen closely. 99esteees 03-31-06, 05:57 PM Thanks danbuc I will keep that in mind. Eldo, very rarely do I hear it. Although it does run from time to time. It's hit and miss. eldorado1 03-31-06, 06:28 PM 99 seville I assume?
Fuel pump relay is in the "rear junction block". The relay is grounded through a black wire to a place called "behind right side of rear seat". Fuel pump relay signal from ECM comes to it from a dark green/white wire from pin 36 of the ecm, connector C2 (? if that makes sense?).
Now what you can do is make sure the wiring at the fuel pump relay connector is working fine. Make sure it has ground and power. Check to see if the signal from the ECM is arriving there (on the dark green/white wire) when the key is put into run for the first time. You'll only see it for 2 seconds.
If you're feeling daring, you can try connecting the "power" pin to the "output to fuel pump" pin to see if it turns the fuel pump on. If you do this, be extremely careful. Use a length of wire and just touch the two contacts. Expect a spark. If you short the wrong things, you'll blow the fuel pump fuse. No biggie. 99esteees 03-31-06, 06:34 PM Sounds like a task that I'm not able to get into with the bad weather coming in. Might just let Cadillac take a look at it Monday unless the weather clears. I put a new relay in to no avail. Thanks for the diagram though. eldorado1 03-31-06, 06:45 PM It's probably a loose ground 99esteees 03-31-06, 06:52 PM If it clears up tomorrow I am gonna trace the wires down. Thanks for the ideas. 99esteees 04-02-06, 05:52 AM Well, I managed to further diagnose problems and eliminate any fuel problems. Somehow, it managed to catch my eye that my lights werent always accurate. Such as when I would turn my key to the ON position, sometimes Service Engine Soon would come on, and other times it wouldn't. That led to to play around a little bit. When the Service Engine soon light comes in, the fuel pump runs and the car starts. When it doesn't, the fuel pump doesn't run and the car won't start. I can keep swapping the key back and forth and know when it will start now. It seems as if I do it very fast and a little hard to the right, the SES always comes on. This is leading me to think it is either A.) a bad ignition or B.) Ignition Control Module.
Any input guys? eldorado1 04-02-06, 10:48 AM yeah, sounds like a bad ignition switch. So when you put it in run, getting ready to start it, some of the dash lights never come on? 99esteees 04-02-06, 10:55 AM yeah, sounds like a bad ignition switch. So when you put it in run, getting ready to start it, some of the dash lights never come on?
Right. For it to start, the SES light should come on, and when that comes on I here the fuel pump start running. It's just hit and miss when it comes on.
I just went and looked up Ignition Switch and it's not showing any parts at partsamerica.com. It has to be something in the ignition. My vote is for the ignition switch. Iamatarg posted a complete parts list in the Tech Tips section (first sticky). Here's the link.
http://www.cadillacforums.com/forums/cadillac-tech-tips/32489-parts-lists-online-seville-98-04-a.html 99esteees 04-02-06, 04:30 PM My vote is for the ignition switch. Iamatarg posted a complete parts list in the Tech Tips section (first sticky). Here's the link.
Great! Do you think the ignitions are the same between the SLS and STS? Most likely. I see no reason for them to be different. scporter 04-07-06, 08:46 PM I had a similar problem on a 1996 Suburban. Sometimes it would start and sometimes it would crank and not start whether the engine was hot or cold. I gave up trying to figure it out and took it to the dealer.
The problem was an intermittent fuel pump. They said it took some doing to find it (it was in the shop for 6 days) but eventually the fuel pressure gage read 13psi instead of the 45psi needed for Subs. I know the fuel system is different for the N-Star, just a thought.
Scott. 99esteees 04-08-06, 06:48 PM Thanks for the input. It turned out to be the ignition switch and is working wonderfully now :) |
