View Full Version : Newbee with Questions on 1996 Deville
brenark
03-27-06, 08:30 PM
Hello
I have a 1996 Cadillac Deville that I bought in 2003. I have put 50000 miles on the vehicle. I purchased the car from a friend to settle his mother's estate. I have to say that the Northstar engine is awesome! I never would have believed that Detroit could produce such an engine!
The car has 120000 miles and is starting to have some problems. I have oil leaks at the rear main seal and the lower engine block joint (at the crankshaft). The dealer quoted $3500 for repair. I use about 1 quart of oil every 800 miles. Anyone have an opinion on the oil usage. I am not going to pay the dealer $3500, so my only recourse would be to continue to drive the car as is or attempt to repair the car myself. I have tackled large automotive tasks before, but I have never removed an engine. I am a Mechanical Engineer and am confident that I could repair the engine myself, however, trying to remove the engine from the vehicle and get it on a stand gives me the "shakes".
Also, I have an annoying hydraulic lifter tap. It is noticable with the engine at idle (warm and cold). Does anyone know how to isolate a malfunctioning lifter? I have tried the mechanics stethoscope, but cannot pinpoint the noisy lifter. At almost $50 each for a lifter, I don't want to replace any more lifters than absolutely necessary! Is there a benchtop test I can use to isolate the noisy lifter?
Any help would be greatly appreciated.
This forum is very informative. I learned a lot of information searching the discussion groups.
CADDYBLACK99
03-28-06, 08:25 AM
Welcome,
Thanks for joining the forum! I will move this thread to the Deville section for better visibility. Good luck.
Paul
Ranger
03-28-06, 12:21 PM
Go to the top left of this page, click on Technical Archives and read up on oil consumption.
brenark
03-28-06, 08:09 PM
Ranger
Thanks for responding. I have read-up on oil consumption. From what I read, "normal" oil consumption is anywhere from 1 qt every 1200 miles and up. I don't really know what I am consuming and what I am leaking out through the rear main seal and the crankcase joint. All I know is that I add a quart about every 800 miles. The usage has been steady over the past couple of years (the leak has been going on that long). I guess I shouldn't be concerned unless the oil usage rate increases.
Do you or anyone know how to identify a noisy or collapsed lifter? I am pretty sure I have a lifter tick, but I have not been able to isolate the noise with a mechanics stethoscope.
Anyway, thanks again for responding! This site a a great resource!
Ranger
03-28-06, 09:28 PM
I am really not sure on how to check the lifter other than the stethescope. Short of removing the cam covers, try a can of Marvel Mystery Oil or a qt. of trans fluid in the crankcase. Maybe that will free it up.
Jim_mack
03-29-06, 01:03 AM
"Marvel Mystery Oil or a qt. of trans fluid" Ranger could you expand on this, is MMO anything like slick 50 and what do you think of MMO and SL50 for engine longevity......Jim
Ranger
03-29-06, 05:50 PM
Slick 50 is snake oil.
MMO has been around for years and is basically a solvent. It is pretty good at freeing up sticky lifters of yesteryear, but with todays oils, I really don't know if there is tha much of a need for it, though it is still sold.
Trans fluid likewise is another old mechanics trick. It is very high in detergents and is supposed to do a good job at cleaning, but again, with todays oils it should not be needed. Years ago (early '70's) I used to put 4 qts of oil and 1 qt of trans fluid per oil change.
I would only use either today as a lasst ditch effort if I thought I had a sticky lifter.
