View Full Version : where is it?.
creeker
03-26-06, 12:49 PM
Hello, I just bought a 1980 coupe deville and I cant find upper ball joint grease nipple, I heard I have to remove tire to see it,is it on the side of ball
joint housing?, any suggestions how to lube it without having to remove tire.
Tnx Creeker
The Ape Man
03-26-06, 08:40 PM
Should be 12 O'clock right above the ball joint unless someone screwed a different fitting into the thing. Tire should not be in the way.
creeker
03-26-06, 09:45 PM
Nope, nobody home,I've lubed lots of cars,this is first one that the upper is not directly above bottom grease fitting, thanks .
Creeker
