View Full Version : thermostat
dav4knee
03-26-06, 12:54 PM
Where is the thermostat located on the 2001 deville? Is it easy to replace?:confused:
Ranger
03-26-06, 07:39 PM
It is easy to replace. It's at the engine side of the radiator hose. I forget if it is the upper or lower but a quick inspection should tell if no one else chimes in.
caddydaddy
03-26-06, 10:49 PM
If you look at the waterpump housing, there will be a black thermostat housing that has the rad hose going to it. Just remove the bolts for that, and it's there. Very easy to do!
C170B
03-27-06, 12:18 AM
Be sure to use a geniune GM thermostat or exact orig OEM.
Replace thermostat every few years without question or symptoms.
There are circumstances that can cost you an engine $8,000! High price for a 15.00 part.
They are designed to fail . The metal covering of the WAX MOTOR is so thin it develops micrscopic cracks loses wax starts slow failure.
You will find a record of new part numbers for improved thermostats and thermostat housings. Shows we are trying however the industry needs to sell parts lots of parts.
Just do it.
