Drew Endly
03-25-06, 02:50 PM
is this what i need to remove in order to take off the front bumperhttp://img521.imageshack.us/img521/561/boltsbig7yb.jpg
| View Full Version : removing the front bumper!!! Drew Endly 03-25-06, 02:50 PM is this what i need to remove in order to take off the front bumperhttp://img521.imageshack.us/img521/561/boltsbig7yb.jpg ChicagoCTS32 03-25-06, 03:07 PM Check this: http://www.cadillacfaq.com/faq/answers/headlights.html Drew Endly 03-25-06, 03:26 PM ive been there like a thousand times but the directions are vague, they give no oreintation of where things are ChicagoCTS32 03-25-06, 03:57 PM Sorry I can't be of any more help... I've never done this. Good luck Mbai2 03-25-06, 04:00 PM You need to loosen the 2 bolts and remove the hex nut. Devil_concours 03-25-06, 07:53 PM You need to loosen the 2 bolts and remove the hex nut. make sure you either have another person helping you out or get soft cloth on the ground. like mbai said above you remove the hex nut and loosen not remove the 2bolts and you can pull the bumper towards the front and it will fall straight down. | |
