View Full Version : Front Wheel Bearing - part question
JimHare
03-24-06, 05:36 PM
Hey guys. Gotta replace the R/F wheel bearing on the 02 Deville. Local GM dealer wanted $400+ for one wheel. I can't see it could be that tricky a job. $330 for the part... ???
I searched around RockAuto, GMParts Direct, AutoZone, Napa, etc. and found bearings ranging from $175 to $200.
Question is, some parts are noted as for a car "W/O heavy duty brakes" - in fact, the parts as pictured on AdvanceAuto's site look quite a bit different.
Can anyone shed some light on this?
The first (left) pic is an "SKF Spindle Hub: Front Wheel; W/O Heavy Duty Brakes; 2 Required Per Vehicle" at $200 bucks, the right t/n is "BCA Hub Assembly; Exc. Heavy Duty Brakes" at $197.77
I assume since it's a base Deville, it does NOT have the "Heavy Duty Brakes" ?
Dadillac
03-24-06, 07:56 PM
The first pic shows the hubs backside, where it mounts to the knuckle. The secong pic shows the frontside, where the wheel mounts to. Not sure about the HD brakes. I do not believe that there was an option for that. Curious; why are you changing the hub? What symptoms do you have, that you are trying to fix?
Don
Ranger
03-24-06, 09:25 PM
Don't assume anything Jim. Check your RPO codes. I thought my '97 was a run of the mill Deville til I took it in for the fuel rail recall and was told it was a "Limo" per the vin. Not sure what that meant (it was not a convert as it only had 17K when I bought it. Point is, that may have qualified it for HD supension or brakes and I had no idea.
JimHare
03-24-06, 10:41 PM
Don
The right front has the "wheel bearing going bad" noise. Narrowed down to that after eliminating interior ventilation fans, engine, transmission, tires and brakes....
130,000 miles on her, I guess that's not all that bad.
JimHare
03-24-06, 10:43 PM
We bought it as an off-lease vehicle. But I'll check the RPO - they're in the trunk somewhere, right????
I may enlist my ersatz son-in-law to help pull the bearing. The job doesn't look all that difficult, once you get the rotor and caliper out of the way.
Thanks
Ranger
03-25-06, 12:12 AM
Yeah, I think the RPO codes are on the underside of the spare tire cover. When I did the hub & bearing on my '92 Deville it took me less than an hour, and that was the first time I had done one.
Terry Lange
03-27-06, 12:27 AM
I went through the same bs while trying to order a new front hub for my 2001 DTS. All of the internet discount parts houses listed a first design and a second design for that year. The Cadillac dealership parts dept. was of no help, since it was apparent to them that I wouldn't be ordering the part from them. They told me that they wouldn't be able to tell if the hub on my car was a first or second design without pulling the old one off and inspecting it. I then went to another GM (non Cadillac) dealership, who was able to tell me which one was on my car based on the VIN only. I ordered the part through gmpartsdirect.com for $187.00 (shipped) and had a local mechanic install it for another $85.00.
JimHare
03-27-06, 09:55 AM
My son-in-law is going to take it with him this week when he goes back to work and do it. He's a tech at a Honda dealer (aiiiiiiiiiiiiiiiiiiiiiiiiiiiii!!!!) but there's a GM dealer right across the street. He'll be able to get the part at a hopefully better price, and slap it in for us after his regular shift.
I guess it always help to know someone in the bidness... :bouncy:
97DevilleBeige
03-27-06, 10:37 AM
In response to Ranger's reply about having a limosine conversion code in the VIN, Cadillac told me the same thing for my 97 Deville when I called them when I was having gasket/engine problems. When I was caught by suprised and told them I don't have a limosine, they clammed up and didn't tell me any more about it. I am very curious what differences there may be with it from a regular Deville. I'm afraid that the frame is in two peices joined together in the middle so it can be split and streched easily but I have no idea. If anyone has any information on this, it would be greatly appreciated. Thank you.
Ranger
03-27-06, 12:28 PM
Well in my case, the car only had 17K on it when I bought it, so it would not have been cost effective to cut it in half, stretch it, and put it back to original for 2-3 years and only 17,000 miles. I also asked what the differences where and the answer was vague but the dealer said maybe ashtrays in the rear, heavier suspension etc. Had it for 107K and never a problem.
