rgh1016@comcast.net
03-22-06, 03:48 PM
I have recently experienced fault code B-1347 (Low Coolant). Resetting the code permitted the a/c to again operate but the air output from the condenser was cool at best even with the temp control set at 60 degrees.
A check of the low-side pressure showed 38 psi (normal) but there is noise eminating from the accumulator anytime the compressor is engaged. This noise is loud enough to be heard inside the car. Additionally, if the a/c has been off for an extended period ( a couple of days) there is a loud thud at the accumulator when the a/c is first turned on.
Question:
Is it possible for an internal failure of the accumulator to cause B-1347 to set on a fully charged system?
GM has replaced the original accumulator (P/N 1132695) with a new part (P/N 88968517). Is this because of a higher-than-normal failure rate of the original accumulator?
Question:
