: Any issues with 24inch Wheels
03-21-06, 08:17 PM
I am looking into getting 24's w/ 305/35/24 tires.. will i have any issues with the tires rubbing? Also I know the escalade's have the tire pressure system.. do i just have to buy the tire pressure valve systems and have them installed in the rims? I really want 24's but i also thought about doing 22's and lowering... If anyone knows if the bottom pic is the right parts that I will need to install on the new rims that would be great, however i think they look a little big for the size tires that im throwing on.. let me know what you guys have done or what you think i should do... thanks for any input..
03-21-06, 08:19 PM
here is the pic..
03-22-06, 10:41 AM
The tire pressure monitoring system was an option not standard on the 2003's. You might not need to install them. In addition, the monitors don't fit all rims. You have to check if it will fit the rim you are interested in purchasing. There will be some rubbing, more if you lower the truck. Every lade is different in where it rubs but there are ways to stop the rubbing.
