kc81cadman
03-20-06, 01:23 PM
I need some help in determining what would make my 8-6-4 idle fast all the time. It will not kick down, so I suspect the the computer is getting bad signals or no signals at all. I believe it to have the quasi injection system, so it may have a solenoid to enrich fuel mixture for fast idle or a funky TPS may be at fault, dunno. If anyone is familiar with this engine and its controls, let me know.
KC.
Bro-Ham
03-20-06, 01:41 PM
Hi KC,
Find Ape Man on this forum since he knows the V8-6-4 very well.
Good luck!
Dave
kc81cadman
03-20-06, 01:45 PM
Thanks, I will try to PM him if possible.
KC.
Darn, not enough post to do a PM, I hope he reads this.
kc81cadman
03-20-06, 09:13 PM
I got moved! All is better this way. Anywho, does anyone have capabilities to PM Ape Man regarding this issue of mine, it would be much appreciated. I cannot do to limited # of post's, apparently you need 50! Wo, bummer. If someone could accomodate me with an answer it would be great.:):)
KC.
CadiJeff
03-21-06, 12:32 AM
check your idle speed control motor
The Ape Man
03-21-06, 04:41 AM
Look for binding linkage, vacuum leaks and check the stored ECM codes. Sometimes the ISC motor gets stuck and will cause this. Should set a code or 2.
kc81cadman
03-21-06, 08:31 AM
Thanks for the info. It is greatly appreciated. I will definetly check out the motor, which I did not even know existed till now.
KC.
