Well I noticed a day after I got my car that there was a small crack on the dash, up by the defroster vent on the drivers side. Lastnight I noticed that it is now all the way across from teh vent to the leather. UGHH!!
Is this a common thing on these cars? I have not seen anything about cracked dash in my skimming here. Any way to fix it or stop from spreading? Is the hard plastic part of the dash separate, or is the entire dash one assembly with leather and all?
I will try to get a picture after work tongiht and post, just to make sure we are thinking the same part. The part in mine cracked I think got all the way across from apillar to apillar, but I need to look closer..
Least I am not alone. Just a bummer as it was not there when I test drive, but after the weeks in customs and POS trucking Co it was there, very small, maybe .5" not it is alllll the way across..:mad2:
That just happened to mine this weekend, can you get it in tan or do you have to paint it? Does anyone have the instructions on how to change it out? Thanks in advance.
It is available in tan...
It's really easy to change takes about 10 min..
Behind the airbag tab on the pillars is a 7mm bolt..remove it...pull the A pillar out...use a flat screwdriver to pry the old dash out...it pops up. (In several pieces)
Then install the new piece,line the tabs and press down on the rear...install the pillars.....real easy....
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
