Aperformance
03-17-06, 04:05 PM
I thought you'd all like to see our latest project... What do you Think?
| View Full Version : Zoomers New C6 Corvette Cat-Back Aperformance 03-17-06, 04:05 PM I thought you'd all like to see our latest project... What do you Think? Aperformance 03-17-06, 04:09 PM C6 LS2 Corvette Final Dyno Results Zoomers Max POWER = 350.63 Stock Max POWER= 332.02 Max POWER Gain = 18.61 hp Zoomers POWER @ 5900 RPM = 350.50 Stock POWER @ 5900 RPM = 326.96 Power Gain @ 5900 RPM = 23.54 hp Zoomers POWER @ 5200 RPM = 328.98 Stock POWER @ 5200 RPM = 311.31 Power Gain @ 5200 RPM = 17.67 hp Zoomers Max TORQUE = 337.16 Stock Max TORQUE = 329.04 Max TORQUE Gain = 8.12 ft lbs Zoomers TORQUE @ 5900 RPM = 308.00 Stock TORQUE @ 5900 RPM = 287.32 TORQUE Gain @ 5900 RPM = 20.68 ft lbs Zoomers TORQUE @ 5200 RPM = 329.38 Stock TORQUE @ 5200 RPM = 311.31 TORQUE Gain @ 5200 RPM = 18.07 ft lbs SoCadillac 03-22-06, 10:14 PM Ron, Wow, they look outrageous! How much weight did you reduce compared to the factory setup? Aperformance 03-23-06, 01:48 PM Ron, Wow, they look outrageous! How much weight did you reduce compared to the factory setup? Not quite sure we'll have to get a weight on em... HTrides 05-18-07, 05:27 PM Do you have a sound clip of what they sound like? I have a 2007 C6 and I am very tempted to put these on. I have the car at a shop getting customized right now. Thanks. Karl Aperformance 05-18-07, 06:00 PM Yes here's a sound clip: http://zoomersexhaust.com/video_corvette/ Also Check out www.youtube.com (http://www.youtube.com) and search "Zoomers Exhaust" or "Zoomers" and there are a few on there as well. If your interested in purchasing we also have a Quad tip set up as well. Duals $1399.00 Quads $1499.00 Ron 949-916-3240 or 866-4Zoomers HTrides 05-19-07, 08:46 AM Very nice sounds. I like the single pipe set up. Reason, is I'm making a custom center screen exhaust diffuser box in the middle between the space where the stock exhaust had the space. If I use your single exhaust tip style is the space in the middle the same as the original C6 exhaust or even a little more? That would be perfect. Were making a custom Ferrari F430 style air diffuser center triangle box and I need the center clearance the same as the stock exhaust would have. But I want to upgrade the exhaust because we want to sell the entire set up and make sure it can work with at least one aftermarket exhaust company. See my site for products I have already made for Hummers & a few on the C6 corvette tab. Thanks again. Karl Hi-Tech Custom Concepts www.hitechcc.com | |
