codes, codes, and more codes
I just had a bunch of codes pop up on my 2008 STS-v
C0561- system disabled (abs)
c 0253 - steering wheel alinement sensor
My left front and right rear wheel speed sensors
no centering information
all four of these came via a scan tool (clearly)
My traction, abs and stability warning light read outs across the DIC
I checked out some older threads and found that 1 guy was having a similar issue - he replaced the wss on his right rear and that did not fix the problem - then replaced the steering wheel, said that fixed problem.
Has anyone else found themselves in the same boat? I thinking about starting with the steering wheel. Has anyone replaced this sensor? how hard is it? can you aline the steering wheel after you've got it all back together or is it an alinement shop issue?
thanks in advance for any info
also has anyone used the online service manuals - 30 bucks a year seems to good to be true and a much better deal then hundreds spent on the paper copy, hows the content?
