View Full Version : Adding Sirius
triggerbjr
03-14-06, 07:28 AM
I would like to change to Sirius on my 2005 Platinum ESV. Any help on the pitfalls, best unit, and best way to install would be greatly appreciated.:bigroll:
NOCLRNCE
03-14-06, 10:17 AM
Do you have the stock radio? I know there is a Pioneer PNR-1 Sirius radio, but you have to have a Pioneer deck to use it. The antenna that is on your ride will work you just have to trim the plastic around the connector.
triggerbjr
03-14-06, 03:31 PM
I have the touchscreen Nav OEM unit.
gredneck
03-14-06, 08:24 PM
I used this:
http://www.logjamelectronics.com/soundkngm1v3.html
and this:
http://cgi.ebay.com/SIRIUS-SIR-KEN1-SIRIUS-ADAPTER-FOR-KENWOOD-RECEIVERS_W0QQitemZ5877703904QQcategoryZ60208QQssP ageNameZWDVWQQrdZ1QQcmdZViewItem
I used the stock xm antenna and everything plugged in fine.
for the conversion box you need constant power, there is a fuse box under the dash.
here is another link:
http://www.cadillacforums.com/forums/cadillac-escalade-ext-esv-forum/50479-convert-sirius.html?highlight=sirius
read post #9
I have the touchscreen with Nav.
palade06
12-28-06, 05:09 PM
Wait a second, I don't understand...so with this all switched over, will you still be able to use the oem 6 disc cd changer? Also where is the antenna going to mount?
Viking88
12-28-06, 05:38 PM
http://www.crutchfield.com/S-XkPlOcDqWb1/cgi-bin/ProdView.asp?search=sir%2Dgm1&i=607SIRGM1
In my 04 with Nav, CD chager still works, used the stock antenee. Read the reviews that customers wrote, its not hard.
slk230mb
12-28-06, 05:55 PM
:yeah: It's the easiest solution to the issue.
TMW597
01-01-07, 12:14 AM
Here you go: http://www.jpcustoms.com/store/customer/product.php?productid=17466&cat=&page=
benamaster
01-01-07, 01:14 AM
Thats the only way to go and its on sale too cheaper than JP Customs though they probably would match Crutchfields price.
c6am
01-03-07, 08:07 AM
Do you have XM already? If so, the install is simple.
I used the SIR-GM1 from Crutchfield on all my GM's. Unplugged the XM cable, plugged in the Sirus cable and reused the XM antenna cable. Works great. Had it for 8 months now with no issues.
CadiLake
01-06-07, 08:55 AM
Crutchfield's SIR-GM1 looks great but it says it is not compatible with 2007. I wonder if there is a SIR-GM2 in the making.
CadiLake
01-06-07, 09:23 AM
I just spoke with a Crutchfield rep and there is no known update for the SIR-GM1 and he confirmed it is not compatible with 2007. I would expect they will eventually update compatibility. Anyone with experience on 07?
