hey guys, got a new rear swaybar (Dorman) brand, its huge compared to stock 1inch i think, first of all it had a sticker saying this side down which is def wrong because it wont fit rite, the bends it has make it only go in one way, i figure they just put it on wrong side, problem is the endlinks are not long enough to go through the hole in bar all the way, the nut can still be tightend down nice and tight its just the threads dont come through the hole all the way. do you thing the links will eventually break? im pretty sure the links are mevotech, i dont know if the oems were longer threads. i had my mechanic put endlinks all the way around, front struts and a front sway in an attempt to kill this unknown clanging,(didnt) and just got some revtech bushings to go in upper&lower control arms, hopefully will cure it.
sorry i meant Revshift, bushings, btw how do you edit post on this site??
