View Full Version : MSD coils? I hit 104
96-deville-man
03-09-06, 10:17 PM
Well i got my car running again. changed the spark plugs wich fixed the rough idle. cylinder 5 was fouled. I must say it was really easy to chang them. then took it out for a test ride and man it ran great!! even hit 104! and it was still climing but thats way to fast for the public streets. but it was the dump road wich was empty except for me and 3 ricers lol.
Now back to was i posted this for. Im thinking about getting 4 msd coil packs. for wich i will later get the interfaces and controler. has anybody used them? what kind of gains will i get if any?
96-deville-man
03-09-06, 10:44 PM
Also wich would be better the
msd coil
Maximum Voltage:40000Turns Ratio:80:1Primary Resistance:0.350 ohmsSecondary Resistance:7.8K ohms
or the
accel
PRIMARY RESIST 0.5 OHMS
SECONDARY 8.0 K OHM
TURN RATIO 75:1;
MAX VOLTAGE 45000V;
Ranger
03-09-06, 10:46 PM
You won't gain anything. If the coil puts out enough voltage for the spark to jump the gap and ignite the fuel, it is doing it's job. It can't do any better than ignite the fuel.
96-deville-man
03-09-06, 10:51 PM
yea but upgraded coils should produce a stronger spark. if i supercharge i will need it also i dont think stock coils would work to well with an msd interface and controler.
eldorado1
03-09-06, 10:56 PM
Not that I doubt you, but how can you afford a supercharger at 15? I could barely afford a rust bucket to drive at 16... A supercharger hasn't been done, and is bound to set you back at least $3000. Not including labor and tuning, which I have to assume you'll be doing.
96-deville-man
03-09-06, 11:22 PM
i have a buddy who i will have do the tuning. I will not be supercharging it for a while just planing ahead. i will be haveing headers made after i save up about $600 for them. when i do supercharge it i will have alot more than $3000 in it because i plan on having a full custom build done on the engine to make it safe to run like 12psi daily and upto like 20psi on the track. I wanna build it were it is very durable at high boost and take a beating.
eldorado1
03-10-06, 12:00 AM
what in the world are you going to do with a FWD cadillac with 700+hp?
To partly answer your original question, it's likely neither coil will give you much hotter spark than stock. A CDI system would be what you want, and I don't think anybody has one for the northstar ignition system.
96-deville-man
03-10-06, 12:08 AM
main reason i love power and comfort. second who els has one?
i plan on running a full msd setup.
Four (4) GM 2-Tower Coil Packs #8224
Four (4) GM Coil Interface Modules #8870
One (1) DIS-4 Plus Ignition Conrols #62152
the DIS-4 has a 2 step rev limit so i could set it lower for a good launch. i think that this is the best setup i could run.
and how much is the current price on a tb and spacer from you?
STS 310
03-10-06, 12:31 AM
Wow, and OBD 2 says it will be "okay"?
96-deville-man
03-10-06, 12:33 AM
not sure what you meant there. could you refrase that?
94CaddyConcours
03-10-06, 03:56 PM
End of the story
eldorado1
03-10-06, 03:59 PM
$250 shipped for an 80mm throttle body and spacer :thumbsup:
Ranger
03-10-06, 05:01 PM
I think it was Mark99STS or something close that just did a custom supercharger. He even has a video of it posted. If I am not mistaken, he said it set him back $12,000. It may be in the Seville section.
eldorado1
03-10-06, 05:46 PM
That was a turbocharger, but the price is a pretty good indicator of a "job well done". I think you could do a centrifugal supercharger setup for about $3000 if you did all the work yourself. You'd need a higher flow fuel pump, fuel injectors, a piggyback ECM, and a head unit. Mark went the extra mile with a custom fuel rail setup (not really needed) and an intercooler. I'm sure a part of that $12,000 included tuning costs.
Tommy Deville
03-10-06, 06:02 PM
Headers o a N* thats an idea, I wonder how hard it would be to do and how much more power u could get
eldorado1
03-10-06, 06:08 PM
quite hard unless you don't mind a pipe hanging down under your car... power would probably be pretty significant.
fubar569
03-10-06, 08:10 PM
anyone have a N* exhaust manifold off the car to trace out for me? i'd toss a buck or two your way if you can provide me with what is essentially what i'd use to have my friends machine a set of flanges for me..or are the flanges available from elsewhere?
eldorado1
03-10-06, 08:15 PM
They used to be available off a person on ebay for cheap, like $15... But he stopped selling them or something. I'd like to pick up some spare manifolds to do some work on if anybody has them laying around...
fubar569
03-10-06, 09:11 PM
chrfab.com has them for i tink 90 bucks and headersbyed.com has them for i think 110 or 115...ed's are 1/4" steel...not sure about chr's...i'd like to score a set and try to fiddle around a bit
96-deville-man
03-10-06, 10:12 PM
Im gonna try to run a roots type but i dont know if i can get it to fit. more than likly end up running a centrifugal. I will be having my buddy doin the piggy back setup he knows his stuff hes got a viper piggyback controller hooked up to his 1500 ram.
I dont think ill have an intercooler.
from what i have been reading im expecting about 15hp probably more some people have said up to 40hp.
let me see what i have after work sunday is should be close!
