View Full Version : Intake manifold
cady75
03-09-06, 07:31 PM
Anybody out there know of Boston area shop that could cut out the plenum for me on intake manifold. I had new exhaust, with modern cat put on magnaflow so now I'm looking front more air in? also with larger opening can I put orignal carb directly on or do I need adaptor. I'm tempted to switch over to Edelbrock. Don't want to affect hood.
zonie77
03-09-06, 09:09 PM
I'm not around Boston but any automotive machine shop should be able to do it.
terrible one
03-10-06, 12:06 PM
Yeah, any machine shop should be able to do it. The original carb will fit directly in place. You aren't do;ing anything but cutting the plenum out. The carb pad will remain the same. You could also do it yourself if you have a bit of know-how and access to a die grinder.
davesdeville
03-12-06, 04:29 AM
The center cut manifold modification will benefit with the addition of a 1" carb spacer as well. If you want to change carbs (I wouldn't, the QJet is IMO the best carb for a street car period) you can use a 1" spacer/square bore adaptor.
74eldog
03-12-06, 09:44 AM
how many more horses can u get by doing this?
davesdeville
03-13-06, 05:18 AM
Never been dyno tested AFAIK. But the Edelbrock is apparently worth around 20hp, this flows almost as well - make your own conclusions.
74eldog
03-13-06, 03:50 PM
thanks bud
