: any aftermarket battery that fits?
sharky1
03-09-06, 01:23 PM
my Delco is dead at 3k miles...seems this battery is shorter than most replacements....any help? Thx
dqw1
03-09-06, 01:26 PM
Any reason why you don't get it replaced free under warranty?
sharky1
03-09-06, 01:41 PM
cause I figure ill have the same problem again?
dqw1
03-09-06, 01:54 PM
I had mine changed out and no issues since. I hope there's not a another bad batch of battery's out there again. Sorry for your luck.
sharky1
03-09-06, 02:45 PM
surely SOMEONE has gone to an aftermarket?
V-Smooth
03-09-06, 02:54 PM
Try Optima...I thought they made a replacement for our V's...
nikon
03-09-06, 03:03 PM
can you get an optima w/out top post?
V-Smooth
03-09-06, 03:12 PM
http://www.1st-optima-batteries.com/
Models D34/78 (yeller) & 75/25 (red)
They have the GM side battery terms as noted...haven't tried ordering one for a V yet...hope this helps
ctsvett
03-09-06, 03:28 PM
I would love to put this info on the FAQ...
Has anyone actually installed one of these models of Optima in a V... I wont put it up there 'till I get confirmation from someone (pictures would be nice)...
Reed
MescalVto
03-09-06, 04:29 PM
Optima is the best, but you should try the free one under warranty first: mine has been fine since warr. replacement . . .:thumbsup:
SoCadillac
03-09-06, 04:55 PM
http://www.optimabatteries.com/publish/optima/americas0/en/config/product_info/automotive/starter/spec_sheets.RowPar.0001.ContentPar.0001.ColumnPar. 0006.File.tmp/75_25_082304.pdf
http://www.optimabatteries.com/publish/optima/americas0/en/config/product_info/automotive/deep_cycle/spec_sheets.RowPar.0001.ContentPar.0001.ColumnPar. 0010.File.tmp/D75_25_082104.pdf
SBONES
03-09-06, 06:29 PM
i have the yellow top..
sharky1
03-09-06, 06:34 PM
question for Bones....did it fit height wise? my search for a replacement , the problwm was, other batts were taller...ours is a very short battery...Thx...model #?
SBONES
03-10-06, 01:48 PM
the yellow top fits fine...at-least in mine..
keeksv
03-10-06, 01:51 PM
Which model # yellow top?
SoCadillac
03-10-06, 01:53 PM
If you take a look at the two links I posted above, they give the battery dimensions.
keeksv
03-10-06, 01:59 PM
I would still like to know which one actually fits in the car, in real life, including the top terminals before I plunk down 150.00 for it.
thanks for your help
Mat347
03-10-06, 06:37 PM
I've had the yellow top in mine, and the hood was lifted about 1/4" when it was closed all the way due to the top posts. I have since gotten the red top specified for GM , it fits and I no longer see the hood lifting.
ctsvett
03-10-06, 08:06 PM
Can someone provide a picture and a model number? I am reluctant to post this on the FAQ based on current info... One person shows a "yellow" top and says fits fine, another posts and says it doesnt work (hoot lifts)... I am not knocking you guys, but we have not seen a model number yet and someone convincing me.
I will not put this on the FAQ until someone can give me the 100%... I dont want to mislead anyone... I dont need a battery yet, or I would go test this.
thanks!
Reed
keeksv
03-12-06, 01:05 PM
Reed:
I'm going to look into this as my battery is kaput...and I have had great luck with red-tops in my other cars..
ew
ctsvett
03-12-06, 09:18 PM
cool thanks... I want someone to do it actually before I post it on the FAQ... Dont want to mislead anyone...
Reed
SBONES
03-13-06, 09:34 AM
wow, i never noticed befor....my hood does stick up a hair or two...i guess not enough to worry me...but i never noticed it.
RobzBLKV
03-13-06, 01:14 PM
My brother has had three cadillacs over the past few years and two of them had early failed batteries. The replacements all had no problems. Get it fixed under the warranty. If it fails again, worry about after market.
Mat347
03-13-06, 03:01 PM
The part # on the battery is RED75/35.
SBONES
03-13-06, 07:20 PM
dont you mean 75/25
slow35th
04-23-06, 05:49 PM
The Yellow top and Red top show the same dimmensions in height in inches (7.625) but the red top shows to be several mm shorter (193.7 mm vs. 196.9 mm.) under metric dimensions on the pdfs posted earlier. If those plastic caps rub through to the hood, you'd have quite a spark show.
Has anyone installed a red top in their car and can confirm that the top terminals do not hit the hood?
keeksv
04-23-06, 07:50 PM
Yeah..know what you mean. Tried one and didn't like the fit. Took the car to the dealer for a new warranty Delco, and bought a battery tender. Your Nav and all that crap activate every so often, even without the car on, from what I'm told, so after a while sitting, the battery drains, and drains. I'm sure a fully charged stock battery will hold up for weeks of sitting (from experience), but once it gets run down a bit (i.e., after several one week rests) you may have a problem....
V-Max
04-23-06, 08:49 PM
Modern automotive electrical systems can sure drain the same battery used in the past. Late model Mercedes Benz's use two batteries!
Might want to disconnect Onstar with something less than OE style battery. When the car is delivered to the owner it may have sat idle a few times and deep cycled. Either driving it or battery tending may be the long term answer.
Norm - who just put his back on the 'tender
http://www.beretta.net/board/ib3/ikonboard.cgi?act=ST;f=9;t=261;st=225
Flyboy
04-23-06, 09:36 PM
Mine failed......last week, one dead cell.....replaced under warranty......no problems.
The dealer did say they have been replacing a lot of Delco batteries under warranty (on all Cadillac models), for the very same problem as I had.....just an FYI.
lasstss
04-23-06, 10:13 PM
I havent tried one either. I did get one for my Tundra. I will look tomorrow and see if it fits. Best place to get one is Remybattery.com. I havent found a cheaper price.
mlg
04-24-06, 05:14 PM
dude, had mine replaced under warranyt w no q asked . took 20 min. battery would barely start car after 1hr w radio blaring while shooting hoops. now w new 1 , no probs. use yr warranty while u can...
