View Full Version : 22 Wheel/Tire Question Pics Please...
Sinisterj
03-09-06, 08:58 AM
Hello I was wanting to know if anyone can post or email me some pictures of thier escalade with 22" Wheels that have 285/45R22 tires. I am understanding that 285/45R22 tires are the better way to go so you will not have rubbing issues etc. but I want to see how big of a wheel gap they leave.
Thanks
Kappa-Lac
03-09-06, 03:58 PM
http://www.cadillacforums.com/forums/attachment.php?attachmentid=3910&d=1094503116
jordan00escalade
03-09-06, 07:55 PM
Here's my 2000 on 285/45/22 Nitto NT404 Extreme tires.
Sinisterj
03-09-06, 09:37 PM
So is 285/45R22 a better way to go than 305/45R22? Im confused
05 Cadillac Escalade
03-09-06, 10:04 PM
There is a possibility of rubbing issues if you go with 304/45/22. I currently have 305/40/22 and I love the ride, but I wish I would have gotten the 45 because of the wheel well issue. The gap is just so large. I have heard of people saying they have had rubbing issues with 305/45/22 and people who have said they have not had any rubbing issues with the 305/45/22. It just depends on the Escalade. Every Escalade is different. If you were worried about rubbing, just go with the 305/40/22. Here are some pictures of my Escalade below on 305/40/22.
Thanks.
LADE in the SHADE
03-09-06, 10:43 PM
305/45/22's rub so slightly, that its easy to fiw with a couple of nylon zip ties in black to pull back the inner wheelwell. And a small snip of the lower front lip of the outer fender(I did it with a hack-saw, and believe me, Im no HACKER.) Problem solved!!!!!!!!!!!
jordan00escalade
03-09-06, 10:54 PM
I have no rubbing issues.. Plus the ride is a little better with a 45 series tire, because you have more rubber to absorb shock and vibration from the road. Not to mention that the 45 does fill the wheel well a little better. Try a 305/45 and have them turn the wheel all the way in both directions, you may not have to shave anything or you might. BoomBotz has a 305/45/22 series tire and he doesn't have any rubbing issues. That's the reason I went with the 45 series tire. If your uncomfortable with the 305/45 you can downsize to a 285/45 which isn't as wide as the 305. Thing is to have them test for rubbing before you make your final decision.. Good luck!
Sinisterj
03-10-06, 11:49 AM
So I can have them put the tires on and test for rubbing before I even buy them? I thought I had to buy them first...
integline
03-10-06, 12:41 PM
u just ahve to snip a little bit of the plastic stuff in teh fenders. i used some Cutco scissors and worked great. I would do the 305/45. when i used to valet a guy came in on the 285's or something A. looks tooo small and B. ride was sooo harsh i thought i was in my buddies lowered trucks. go bigger for better ride.
06BlueChip
03-10-06, 02:02 PM
Hey SinisterJ how did that sub install in the rear panel go? Please post some pics of the install and please post your DIY, I've been waiting forever for that. I have 285/45/22 tires on my 06 Blue Chip and they are look great, no rub but they do have some signifigant tire gap. I have the same size tires on my 07 Blue Chip also and they have much less tire gap than on the 06.
Sinisterj
03-10-06, 06:39 PM
hello yes I meant to give everyone an update on that... I had a panel out of an 02 on order and then they came back and told me that they could not get one so after weeks of going backwards and forwards I just gave up... I did install the sub though and had it running for a couple of days and it sounded good! I have pics of the install I can email them to you if you want me to... But basically I gave up on the project because of getting parts difficulties:(
06BlueChip
03-13-06, 12:14 PM
Hey SinisterJ, cant you just post the pics in the thread? If you cant, please e-mail them to me at jchustla@earthlink.net ASAP.
Thanks
