: front spring removal 70 cdv
03-06-06, 04:42 PM
Hey guys i need help on removing my front springs on my 1970 coupe deville. Any help would be much appreciated. Thanks
03-07-06, 12:33 AM
Where do you live, I can try to be over there tommorow! or in the spring!
03-07-06, 01:36 AM
well its usually very easy removing about 2 big bolts and use a jack under the control arm then lower the control arm and install the jack under the control arm to compress the spring OR you might have to use a spring compressor.....available at autozone
