larry_chip
03-17-03, 04:22 AM
i just got a 2003 EXT & Wanted to put 2 10's in the rear somewhere'? but dont know how i can ?
can you guys help?
can you guys help?
| View Full Version : where do i put subs? larry_chip 03-17-03, 04:22 AM i just got a 2003 EXT & Wanted to put 2 10's in the rear somewhere'? but dont know how i can ? can you guys help? BUILDINGCTSAMG 03-31-03, 09:40 PM Larry take it to any car audio place and have them make you a custom box. Im putting new subs into my factory sub spot (only using about 2 inches more room) but they can really create anything you want and it doesnt have to look dorky. Or do it urself by using ideas from crutchfield.com and sounddomain.com STSFreak 04-21-03, 10:50 PM I think that if you can build anything yourself you can build a speaker box. just take a few measurements, go buy some wood and build and carpet your own box.....you will save tons of cash Anthony's Lade 04-30-03, 09:50 AM larry-chip. it seems that you've installed an aftermarket amp :banghead: . Did you hook it up to your stock radio. I need some advice, on how to hook my PPI amp to my stock audio system. In another words, I need to add an amp and 2 subs to my escalade. Please, help. tony:banghead: STSFreak 05-01-03, 07:15 PM its pretty easy....you might have to pull out the stereo deck in order to hook it up. You should receive some sort of instruction with your amp...check that out. Anthony's Lade 05-02-03, 09:42 AM I dont have an amp manual. My issues are: 1. I initially was told to hook up a Hi to Low converter to the back of the Head Unit. But dont know which color wires to connect it to. 2. When went to an electronic store, the technical guy told me that if i plug a conveter, I will fry the entire stock audio system, because stock wiring are optic fiber. This is the first time I've heard this. Hope this is not true. 3. No one (even Crutfield) tell me an accurate answer, when it come to wiring connect an amp to the stock system. I really need advice from you. Please help. PS. Keep in mind that not GM HUs are not the same, ie my corvettes HUs set up are is not the same as of the escalade BUILDINGCTSAMG 05-02-03, 01:36 PM anthony did u call crutchfield customer service/tech support, usually they have every answer ever! Anthony's Lade 05-02-03, 01:43 PM Originally posted by BUILDINGCTSAMG anthony did u call crutchfield customer service/tech support, usually they have every answer ever! I did, crutchfield dont know. larry_chip 05-06-03, 08:05 PM Sorry tony, imy system is all stock, i am waiting till they come out with a box to fit some subs in my truck, because they want way too much to make a custom box. Sorry Bro, | |
