Rex Raider
03-16-03, 09:19 AM
I had a 2000 Monte Carlo SS, and I bought aftermarket 17" wheels for it. I no longer own the car.
Can I put those wheels on my 93 Deville?
I know the bolt pattern (5x115) is the same. Is there anything else I should be concerned about?
Katshot
03-16-03, 09:36 AM
The wheels will most likely NOT have the all important offset required to clear the FWD hubs and still stay inside the wheel wells. Also, the actual hub centers are a critical measurement besides the bolt pattern.
DeVillish
03-16-03, 09:59 AM
is the SS fwd? if it is it might work, i heard some where, dunno if its true, that all fwd GM wheels would work. I dont think its true, but if you have the wheels still, try it and see.
jadcock
03-19-03, 01:10 PM
Yeah, I think it'd work. Both vehicles are FWD, so you should have close to the correct wheel dimensions. I'd take a wheel off your Deville and do some loose measurement comparisons between that one and one from your Monte Carlo. If they're close, bolt one on the Deville and check it out. I'm guessing it'll be a perfect fit.
elwesso
03-19-03, 03:16 PM
I would assume they would fit also......
deanstud
03-19-03, 03:19 PM
Wheels off of my 87 DeVille fit my dadss 90 Lumina, if that helps........
