ase tech
02-27-06, 10:39 PM
I have a 93 sdv with 4.9, according to the fuel data im only gettin 8-9 miles per gallon. I think it might be right because i rest thtrip odometer and had five gallons in it and i was on empty at about 42 miles. I fix cars for a living and ive done a complete tune up on it including replacing the oxygen sensor, fuel filter and doing a fuel rail cleaning. the car has just a little over 100,000 on it. I dont know if it makes a difference or not but the fuel date module thats in it right now is out of my 86 sdv, im hoping im just getting the wrong info from the module. I really like this car but if i cant get better fuel mileage then its going up for sale, I figured ill ask some of you long time caddy owners for some new ideas.
As you probably know, the '86 is a HT4100 I believe but I thought all calculations where done by the PCM. If not, that may be your problem.
I assume you checked the FPR?
ase tech
02-27-06, 11:05 PM
im sorry what do you mean by ht4100, and i am starting to lean towards the pcm
The HT4100 is the 4.1 engine Caddy used for most of the '80's.
I just replaced the plugs, cap & rotor on my '89 4.5 TBI with 100k and got 26 mpg on the highway afterwards. I get about 18 mpg around town if I soft peddle.
With PFI you should be get a couple mpg better than I. I would do some hard, real time calculations of miles/gal and see how it compares to your fuel data center. Hopefully it's just a matter of incompatibility between the '86 center and the 93 PCM.
ase tech
03-01-06, 10:46 PM
Im going toworrow to try to find a fuel data module thats close to my 93 sdv. Thats a good point Kev thanks for the advice. Ill let you know what the outcome is.
91TexasSeville
03-02-06, 06:08 AM
Do not quickly dismiss Ranger's comment about the FPR.
There are two known fuel wasters for the 4.9L. The first being a leak from the fuel pressure regulator, and the other is a stuck or leaky injector(s). 8-9 MPG is very likely according to your post. Also likely not the result from the wrong fuel data module.
On any given bad day, you should average around 16 (15.7-16.2) MPG around town. If not, there is a problem.
