View Full Version : Stabilizing System
Lac DTS
02-24-06, 10:59 AM
Has anyone had a problem with the stabilizing system on a 2001 dts.
A message came up today saying service stabilizing system, does anyone know what it could be and how much it will run me....
caddydaddy
02-24-06, 11:01 AM
Most likely it's a problem with a sensor. And it depends on which one for how much it will cost to fix.
turbojimmy
02-24-06, 11:39 AM
Pull the codes. It's probably the steering wheel position sensor. It's the most common failure with the stability system.
Jim
Lac DTS
02-24-06, 02:10 PM
how do I get the code with out the computer thing
turbojimmy
02-24-06, 03:25 PM
It's in the FAQ somewhere. Without sitting in the car I can't tell you what buttons to push. You hold the ^Info button and the one next to it (ON/OFF I think?) for a few seconds with the key on, engine off. Use the arrows to scroll through the information, ON/OFF to select.
Jim
