: Spare tire with 22's+
brett79
02-23-06, 09:14 AM
I know the height is about the same with aftermarket wheels, but can you still put the spare tire on?
Has anyone had to ride on their 22 or 24's and one donut?
jrs05caddyext
02-23-06, 09:53 AM
I road on a little ass donut and 20s couple months ago. I canít imagine doing that with 22s or 24s. I traveled a couple miles so it wasnít that bad.
brett79
02-23-06, 10:08 AM
Maybe little donut isnt correct. Isn't the spare tire the same size as the stock wheels?
I was just thinking about this, because I am taking a little trip up to NY tonight....and thought, what happens if I blow a tire on my 22's?
jrs05caddyext
02-23-06, 10:29 AM
oh my bad. I guess it would be fine since they are about the same size.
brett79
02-23-06, 11:41 AM
Anyone know if it will be okay?
integline
02-23-06, 11:43 AM
should be fine. yourtraction control system may go weird but should not messup truck. I am not sure, call a cadi dealership.
Boombotz
02-23-06, 07:44 PM
You will have no problem running your truck with a spare as long as you didn't upgrade your brakes to a larger size.
05 Cadillac Escalade
02-23-06, 07:58 PM
I had a flat tire last week on my 22's and had the spare put on. I had no problem at all. The tires were so close in height that it didn't matter. The air-ride suspension also made the Escalade level while I was driving. You will be completely fine while on your 22's. Good luck.
Thanks.
hornyjuan
02-23-06, 08:31 PM
Had this happen to me. Had to rotate the rear tire to the front then put the spare on the rear. PITA!!!
Boombotz
02-23-06, 08:52 PM
I understand. Only works if you didn't upgrade your rear brakes too.
It's not something you think about when you buy your rims.
